Einleitung
In this guide you will learn how to remove the keyboard and expose the inner components of your Asus Vivobook X540SA-BPD0602V. If you need to make any repairs to your laptop, the first step is to safely take it apart.
Was du brauchst
Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
Remove the two battery screws (15.6 mm)
Two top corner screws (12.5 mm)
Six case screws (9.7mm)
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
2 weitere Personen haben diese Anleitung absolviert.
