Einleitung
Opening the back panel of the Asus VivoTab Note 8 is easy; however it is recommended to have a plastic opening tool to pry it off.
Was du brauchst
Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
Pull apart the sides of the casing by hand.
