Zum Hauptinhalt wechseln
Asus VivoTab Note 8 Back Panel Replacement
Was du brauchst
  1. Asus VivoTab Note 8 Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 Back Panel Replacement: Schritt 2, Bild 1 von 2 Asus VivoTab Note 8 Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 Back Panel Replacement: Schritt 3, Bild 1 von 1
    • After pulling the panel off, put it to the side.
Abschluss
Ryan Spencer
756 Reputation
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 562
