Einleitung
If your tablet's battery will not hold a charge, this guide will show you how to replace the battery in 13 quick and easy steps.
Was du brauchst
Remove the tablet from the attached keyboard.
To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
Use the Phillips screwdriver size PH000 to remove the two 1.59 mm #000 screws.
Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
Now that the screen is completely detached, lay the back panel flat on a smooth surface.
Lift the screen to view the inside of the tablet.
Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
Rotate the Tablet clockwise, so that the motherboard is facing away from you.
Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
Remove the two wire connection on the right side of the tablet with the pointed precision tweezers.
Use the nylon or metal spudger to help pry the motherboard from the back panel.
Once the mother board is relieved from the glue, use your hand to lift the motherboard up and to the opposite end of the back panel.
Gently lift the battery over its connection prongs with both hands.
Remove the battery and replace it.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hi...Im trying to disconnect battery and reconnect like pics above to try a reset from black screen of death after updates...I have black screen..it was working fine until then..now I dont even get a power light to show its charging????
