Einleitung
Is there no sound coming from your device? Have you checked all of your sound settings and still have had no success at resolving your sound problems? If you said yes to both questions you are in the right place. This guide will show you how to remove and replace the speaker in your Asus Vivo RT TF600T.
Was du brauchst
Rotate the device 180°, and remove the two 1.59 mm #000 screws at the bottom of the device.
Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
Now that the screen is completely detached, lay the back panel flat on a smooth surface.
Lift the screen to view the inside of the tablet.
Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
Turn the tablet clockwise, so the speaker is facing the right.
Use the nylon or metal spudger to pry the battery from the back panel.
Remove two 0.79 mm #00 screws from the speaker with a Phillips screwdriver size #00.
Eine weitere Person hat diese Anleitung absolviert.
