Zum Hauptinhalt wechseln
Asus VivoTab Smart Battery Replacement
Was du brauchst
    1. Asus VivoTab Smart Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Asus VivoTab Smart Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Asus VivoTab Smart Battery Replacement, Battery: Schritt 1, Bild 3 von 3
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus VivoTab Smart Battery Replacement: Schritt 2, Bild 1 von 3 Asus VivoTab Smart Battery Replacement: Schritt 2, Bild 2 von 3 Asus VivoTab Smart Battery Replacement: Schritt 2, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
      • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
      Frag FixBot
    3. Asus VivoTab Smart Battery Replacement: Schritt 3, Bild 1 von 3 Asus VivoTab Smart Battery Replacement: Schritt 3, Bild 2 von 3 Asus VivoTab Smart Battery Replacement: Schritt 3, Bild 3 von 3
      • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
      • Remove the tape covering the areas marked by the black arrows
      • Remove two 3.7 mm Phillips #00 screws
      • Remove eleven 2.7 mm Phillips #00 screws
      Frag FixBot
    4. Asus VivoTab Smart Battery Replacement: Schritt 4, Bild 1 von 2 Asus VivoTab Smart Battery Replacement: Schritt 4, Bild 2 von 2
      • Be careful not to damage the speaker wire.
      • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
      • Lift up on the speaker with your fingers to remove it.
      Frag FixBot
    5. Asus VivoTab Smart Battery Replacement: Schritt 5, Bild 1 von 1
      • Gently lift the battery pressure plate off of the motherboard.
      Frag FixBot
    6. Asus VivoTab Smart Battery Replacement: Schritt 6, Bild 1 von 2 Asus VivoTab Smart Battery Replacement: Schritt 6, Bild 2 von 2
      • Use tweezers to separate the battery tray from the device
      • Lift the battery tray from the device using your hands.
      Frag FixBot
    7. Asus VivoTab Smart Battery Replacement: Schritt 7, Bild 1 von 1
      • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
      • Detach the battery from the tray by pulling the battery up from the tray with your hands.
      • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-4, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hi
So where is the next step ?!
Albert einstein - Antwort Teilen
Hi
Please answer to me. This is so
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 59
Insgesamt: 4,004
