Einleitung
The tablet comes with two cameras. Replacing the back camera will be the sole focus of this guide.
Was du brauchst
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
Remove the silver plate that sits on top of the camera lens.
Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
Slide the tweezers under the motherboard and lift up to remove the motherboard.
Use tweezers to gently lift and remove the camera from the motherboard.
