Einleitung
This guide will show you how to take apart your device and replace its Digitizer Touch Screen.
Be cautious not to smudge or scratch the screen during replacement.
Was du brauchst
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Remove thirteen 3.7 mm Phillips #00 screws
Unplug the middle, red-tipped ribbon from the device by lifting up on it. This can be done with your hands or with tweezers.
Unplug the camera ribbon by pulling out on it with a pair of tweezers.
Unplug the double ribbon from the device by pulling out on it with a pair of tweezers.
Carefully lift the internal base of the device from the screen, also threading the ribbons through the slots.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Attention: this procedure has a big trap, in which I fell by following it: I have broken the glued connection between USB/power plug-in unit (on the right-side bottom) and its strip cable (visible on the right side and going into a whole on the right side bottom). Result: when I finished the assembly and tried to start the tablet, I only get the 3 blinking of the power LED, saying the the power connection is not OK.
The instructions should mention, that we have to disconnect also the power/USB strip-cable and take it out the whole, without braking the glued connection !!! - So, the photo in Etape 5 should show also the strip-cable still connected to the USB/power plug-in unit (green element on right-side bottom) !! - This in not the case on your Etape 5 photo and I am wondering how you could re-establish this connection when re-assembling the board.
Consequence: I have to find and buy a new power/USB connector (called DC board) which has the strip-cable included, i.e. attached.
Really annoying !
I don’t like this tutorial.
First: as Richard mentioned be very careful to get the flex out of the USB/power plug-in-unit. I broke it as well. It’s a newby thing. Doesn’t matter, it is easy to buy a new one but it takes time off course.
Second: This tutorial has the title of replacing the ** digitizer** but suggests to buy an LCD . Likely many people don’t need to buy a new LCD but a only a reliable digitizer (that’s the frame basically).
Third: Be very cautious about buying a new digitizer. Maybe for a reason it is not part of this tutorial. So you want to replace the digitizer, but there is not a digitizer sold as a part in this tuturial?! Weird. Anyway: I read there were THREE variations of this digitizer, and you really have to buy the one that fits your tablet. Others won’t work. So I suggest to read the flex. I have done this step, and now bought a new, original, digitizer for this tablet. But according a pro it still isn’t a safe buy. I don’t know if he is right, he might be though.
