Zum Hauptinhalt wechseln
Asus VivoTab Smart Motherboard Replacement
Was du brauchst
  1. Asus VivoTab Smart Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Motherboard Replacement: Schritt 2, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 2, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Motherboard Replacement: Schritt 3, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 3, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Motherboard Replacement: Schritt 4, Bild 1 von 2 Asus VivoTab Smart Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Motherboard Replacement: Schritt 5, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 5, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Motherboard Replacement: Schritt 6, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 6, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Motherboard Replacement: Schritt 7, Bild 1 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 7, Bild 2 von 3 Asus VivoTab Smart Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Motherboard Replacement: Schritt 8, Bild 1 von 2 Asus VivoTab Smart Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Motherboard Replacement: Schritt 9, Bild 1 von 2 Asus VivoTab Smart Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 2-4, Sullivan Fall 2016 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,582
