Einleitung
A display can eventually die due to extensive use, or a majority of the times, receive too much damage that it won't function properly. This guide should be followed in order to replace the LCD assembly.
Was du brauchst
Remove the rubber covers for the two screws located at the bottom of the screen.
Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
Place the opening tool at the corner of where the screen meets the base of the laptop.
Pry open the screen along the edge until it is completely off the front cover.
Disconnect each appropriate connector while opening up the laptop.
Remove the cable that connects to the touch display, front camera, and motherboard.
Remove each piece of tape that holds down each cable.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
