Einleitung
This guide will show you how to remove and replace the track pad of your Asus Vivobook Max X541SA-PD0703X. There are no additional parts that you need to replace in order to access the track pad.
  1. Flip the laptop upside down so that the back of the laptop faces you.
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop. Ribbon cables connect the two half so don't remove completely.
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  5. Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets. Pull the ribbon cables out of their sockets. Pull the ribbon cables out of their sockets.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  6. Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  7. Remove the three 3mm Phillips #0 screws from the touchpad.
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  8. Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  9. Remove the touchpad. Remove the touchpad.
    • Remove the touchpad.
Abschluss
Hetvi Mehta
663 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G4, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Mitglieder
7 Anleitungen geschrieben
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 162
