Einleitung
This guide will show you how to replace the Wi - Fi Card of your Asus Vivobook Max X541SA-PD0703X. In order to replace the Wi - Fi Card, you do not need to remove any other parts.
Was du brauchst
Flip the laptop upside down so that the back of the laptop faces you.
Remove the following ten Phillips #0 screws from the bottom of the laptop:
Six 13mm screws.
Four 11mm screws.
Using a plastic opening tool, pry up the palm rest from the bottom half of the laptop.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
Pull the ribbon cables out of their sockets.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
