Einleitung
This guide will help you replace a defective screen, patience and extreme care is required. It will require a major disassembly of the laptop.
Was du brauchst
Remove the four 5mm Phillips #1 screws from the top of the laptop.
Remove the two 6mm Phillips #1 screws from the sides of the laptop.
Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
Using a Phillips #1 Screwdriver unscrew the four 4 mm screws holding the screen holder onto the motherboard.
Using a Phillips #1 Screwdriver unscrew the six 3 mm black screws and the three 2 mm copper screws that are keeping the screen in place.
Using a Phillips #1 Screwdriver Unscrew the four 2 mm screws holding the screen onto the screen cover.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
