Einleitung
A defective Wifi card will prevent you from accessing the internet wirelessly. This guide will help replace it to fix this problem. Manipulating wires are necessary so be sure to remember where the wires are unplugged from.
Was du brauchst
Remove the four 5mm Phillips #1 screws from the top of the laptop.
Remove the two 6mm Phillips #1 screws from the sides of the laptop.
Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
Using a Phillips #1 Screwdriver unscrew the 2 mm screw holding the wifi card in place.
