Zum Hauptinhalt wechseln
Asus Vivobook S500CA Touch Pad Replacement
Was du brauchst
  1. Asus Vivobook S500CA Touch Pad Replacement, Touch Pad: Schritt 1, Bild 1 von 1
    • Turn the device over so the back plate is facing up.
  2. Asus Vivobook S500CA Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 10mm screws and 7 5mm screws) around the perimeter of the back plate.
  3. Asus Vivobook S500CA Touch Pad Replacement: Schritt 3, Bild 1 von 1
    • Remove the back plate by lifting it straight up.
  4. Asus Vivobook S500CA Touch Pad Replacement: Schritt 4, Bild 1 von 1
    • Remove 9 5mm screws around the edge of the battery
  5. Asus Vivobook S500CA Touch Pad Replacement: Schritt 5, Bild 1 von 1
    • Lift up the battery to reveal the battery terminal.
  6. Asus Vivobook S500CA Touch Pad Replacement: Schritt 6, Bild 1 von 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clips.
  7. Asus Vivobook S500CA Touch Pad Replacement: Schritt 7, Bild 1 von 1
    • Remove the silver tape at the edge of the touch pad.
  8. Asus Vivobook S500CA Touch Pad Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the white ribbon labeled “TP” by pulling gently.
  9. Asus Vivobook S500CA Touch Pad Replacement: Schritt 9, Bild 1 von 1
    • Remove 2 5mm screws from the hard drive casing.
  10. Asus Vivobook S500CA Touch Pad Replacement: Schritt 10, Bild 1 von 1
    • Slide the touch pad out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 626
