Zum Hauptinhalt wechseln
  1. Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles. Unscrew the 2 4 mm Phillips head screws by the battery. Unscrew the 2 4 mm Phillips head screws by the battery.
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Remove the panel above the keyboard with a plastic spudger.
    • Remove the panel above the keyboard with a plastic spudger.
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Once the panel is removed, use the spudger to pry out the keyboard.
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  5. Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop. Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Abschluss
Joe Redfearn
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 13-29, Maness Spring 2014 Mitglied von Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 192
