Was du brauchst
Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
Unscrew the 2 4 mm Phillips head screws by the battery.
Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
Now you can fully remove the keyboard from the laptop.
Abschluss
