Zum Hauptinhalt wechseln
Asus W2W-A1 Touchpad Replacement
Was du brauchst
  1. Asus W2W-A1 Touchpad Replacement, Keyboard: Schritt 1, Bild 1 von 3 Asus W2W-A1 Touchpad Replacement, Keyboard: Schritt 1, Bild 2 von 3 Asus W2W-A1 Touchpad Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Touchpad Replacement: Schritt 4, Bild 1 von 2 Asus W2W-A1 Touchpad Replacement: Schritt 4, Bild 2 von 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
  5. Asus W2W-A1 Touchpad Replacement, Front Panel: Schritt 5, Bild 1 von 1
    • Place your fingers or a spudger between the front panel and the rest of the laptop.
    • Pull upwards gently to detach the side you are grabbing.
    • Repeat on the other side until the panel easily peels off the laptop.
  6. Asus W2W-A1 Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 2 Asus W2W-A1 Touchpad Replacement, Touchpad: Schritt 6, Bild 2 von 2
    • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
  7. Asus W2W-A1 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Gently pull the ribbon cable out of its socket attached to the touchpad.
    • You are now able to remove the touchpad.
Abschluss
Nolan Schock
501 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-29, Maness Spring 2014 Mitglied von Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 230
