Zum Hauptinhalt wechseln
Asus X200CA Battery Replacement
Was du brauchst
  1. Asus X200CA Battery Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus X200CA Battery Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Battery Replacement: Schritt 2, Bild 1 von 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Battery Replacement: Schritt 3, Bild 1 von 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Asus X200CA Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
  5. Asus X200CA Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery by the tab you removed the screw from.
    • Replace with the new battery, if necessary.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G2, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 7,315
