Einleitung
This guide will show you how to replace the motherboard of the Asus X200CA Laptop. In this device both components are one piece.
Was du brauchst
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
