Zum Hauptinhalt wechseln
Asus X200CA Motherboard and RAM Replacement
Was du brauchst
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: Schritt 2, Bild 1 von 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: Schritt 3, Bild 1 von 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: Schritt 4, Bild 1 von 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: Schritt 5, Bild 1 von 2 Asus X200CA Motherboard and RAM Replacement: Schritt 5, Bild 2 von 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: Schritt 6, Bild 1 von 2 Asus X200CA Motherboard and RAM Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: Schritt 7, Bild 1 von 2 Asus X200CA Motherboard and RAM Replacement: Schritt 7, Bild 2 von 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: Schritt 8, Bild 1 von 1
    • Lift the motherboard/RAM out from the frame.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G2, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 36
Insgesamt: 9,981
