Was du brauchst
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a Phillips #00 screwdriver to remove the 2 screws.
Use tweezers to separate the 2 coaxial connectors.
3 weitere Personen haben diese Anleitung absolviert.
