Zum Hauptinhalt wechseln
Asus X200CA-HCL 1104G Battery Replacement
Was du brauchst
  1. Asus X200CA-HCL 1104G Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Battery Replacement: Schritt 2, Bild 1 von 1
    • The battery will be easily visible towards to top of the internals. It is a long, black rectangle marked "Li-ion". Notice that the battery is currently secured by three screws. We will need to unscrew them in order to remove the battery.
  3. Asus X200CA-HCL 1104G Battery Replacement: Schritt 3, Bild 1 von 1
    • You will notice that there are two gold screws and one silver screw holding the battery in place. Using the Phillips 1 screwdriver, remove the silver screw.
    • For the gold screws, pliers may be necessary. Be careful not to cut yourself on them; they can be finicky.
    • From here, the battery will lift easily out of the laptop.
Abschluss
Samantha Wahl
301 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 410
