Zum Hauptinhalt wechseln
Asus X200CA-HCL 1104G Headphone Jack Replacement
Was du brauchst
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Asus X200CA-HCL 1104G Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Abschluss
Samantha Wahl
301 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 115
