Was du brauchst
Using the Phillips 1 screwdriver, remove the laptop's back panel.
Pry open the Keyboard/Touch pad.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Detach keyboard and touch screen cables
These are the cable that are holding the keyboard and touch screen together
Use tweezers to remove the speaker bar that is located beneath the touch screen.
Once removed carefully disconnect the clip to the left of the speaker.
