Einleitung
If your battery is giving you a hard time on your laptop, follow this guide.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Remove the following two screws under the rubber caps.
Two 14 mm screws using the Phillips #0 screw driver.
Flip up the following:
The two latches holding the two cables shown(white and black)
Pull the cables free from the latches
Lift the keyboard from the computer
Remove the following screws from the inside of the laptop:
Two 4 mm screws using the Phillips #0 phillips screwdriver.
One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
28 weitere Nutzer haben diese Anleitung absolviert.
8 Kommentare
Merci super!
Thanks for the write up! Easy to follow, Great photos, and worked great!
thanks it worked
Your step by step instructions were so easy to follow. Great job. Thanks! :)
I would like to buy a battery to it, Please suggest me the best portal site
