Zum Hauptinhalt wechseln
Asus X200MA Battery Replacement
Was du brauchst
  1. Asus X200MA Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Take two rubber caps off the back side of the laptop.
  4. Asus X200MA Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  5. Asus X200MA Battery Replacement: Schritt 5, Bild 1 von 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  6. Asus X200MA Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  7. Asus X200MA Battery Replacement: Schritt 7, Bild 1 von 1
    • Slide the battery up and out.
Abschluss
29 weitere Nutzer:innen haben diese Anleitung absolviert.
Vanessa Garcia
1.763 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-24, Maness Winter 2015 Mitglied von Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Mitglieder
8 Anleitungen geschrieben
8 Kommentare
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Antwort
thanks it worked
iqbal nasution - Antwort
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Antwort
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 65
Insgesamt: 35,335
