Was du brauchst
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Remove the black foam and adhesive located on top of the hard drive.
Remove the following four screws:
Four 4 mm Phillips #0 using a phillips screwdriver.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
