Zum Hauptinhalt wechseln
Asus X200MA Screen Replacement
Was du brauchst
  1. Asus X200MA Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Screen Replacement: Schritt 2, Bild 1 von 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Screen Replacement, Battery: Schritt 4, Bild 1 von 1
  5. Asus X200MA Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Screen Replacement: Schritt 6, Bild 1 von 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Screen Replacement: Schritt 8, Bild 1 von 1
    • Slide the battery up and out.
  9. Asus X200MA Screen Replacement, Screen: Schritt 9, Bild 1 von 1
    • Remove the following four 3 mm screws using the Phillips #0 screwdriver.
  10. Asus X200MA Screen Replacement: Schritt 10, Bild 1 von 2 Asus X200MA Screen Replacement: Schritt 10, Bild 2 von 2
    • Lift and separate the screen from the base plate.
  11. Asus X200MA Screen Replacement: Schritt 11, Bild 1 von 2 Asus X200MA Screen Replacement: Schritt 11, Bild 2 von 2
    • Insert the metal spudger into the side of the screen casing. Work the spudger around the perimeter of the casing in a rowing motion in order to release the plastic clips holding the casing together.
    • Place a finger in the space between the casing while undoing the clips to keep the casing from re-closing.
  12. Asus X200MA Screen Replacement: Schritt 12, Bild 1 von 1
    • Lift the half of the casing with the screen away from the other half of the casing and place the screen half on a work space by itself.
  13. Asus X200MA Screen Replacement: Schritt 13, Bild 1 von 1
    • Remove the following six 3 mm screws using the Phillips #0 screwdriver.
  14. Asus X200MA Screen Replacement: Schritt 14, Bild 1 von 3 Asus X200MA Screen Replacement: Schritt 14, Bild 2 von 3 Asus X200MA Screen Replacement: Schritt 14, Bild 3 von 3
    • Use the jimmy tool to peel the following stickers from the screen:
    • The silver sticker near the bottom.
    • The information sticker near the top.
  15. Asus X200MA Screen Replacement: Schritt 15, Bild 1 von 3 Asus X200MA Screen Replacement: Schritt 15, Bild 2 von 3 Asus X200MA Screen Replacement: Schritt 15, Bild 3 von 3
    • Lift the latch holding the component in place.
    • Remove the component by pulling in the direction of the arrows.
  16. Asus X200MA Screen Replacement: Schritt 16, Bild 1 von 2 Asus X200MA Screen Replacement: Schritt 16, Bild 2 von 2
    • Lift the screen from the casing and place the two next to one another.
Abschluss
Alli Krininger
391 Reputation
3 Anleitungen geschrieben
IUPUI, Team S2-G4, Stella Fall 2019 Mitglied von IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 782
