Einleitung
This guide provides step-by-step instructions on the replacement of the speaker of ASUS X200MA. This guide can be used to replace broken speakers or upgrade on this laptop. Use caution when removing the wires and removing the glued speakers with a spudger, as these are delicate processes.
Was du brauchst
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Disconnect the gold cap that connects to a black wire using the metal spudger.
Use the metal tweezers to free the speaker from the plastic clips.
Use the metal spudger to break the bond between the base plate adhesive and the speaker.
Lift the speakers and remove them from the base plate.
To reassemble your device, follow these instructions in reverse [#|order].
