Zum Hauptinhalt wechseln
Asus X200MA Trackpad Replacement
Was du brauchst
  1. Asus X200MA Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Trackpad Replacement, Trackpad: Schritt 4, Bild 1 von 2 Asus X200MA Trackpad Replacement, Trackpad: Schritt 4, Bild 2 von 2
    • Use the spudger to lift up and remove the black plastic covering.
  5. Asus X200MA Trackpad Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  6. Asus X200MA Trackpad Replacement, Mouse: Schritt 6, Bild 1 von 1
    • Remove wider blue strip with tweezers.
  7. Asus X200MA Trackpad Replacement: Schritt 7, Bild 1 von 1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  9. Asus X200MA Trackpad Replacement: Schritt 9, Bild 1 von 2 Asus X200MA Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Vanessa Garcia
1.763 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 21-24, Maness Winter 2015 Mitglied von Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 2,108
