Was du brauchst
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
Take gold cap that connects to a black wire off using the metal spudger.
Remove the following two screws:
Two 4 mm screws using Phillips #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
