Einleitung
If your AsusX202E does not turn on or looses power quickly use this guide to replace the battery.
Was du brauchst
Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
Use an opening tool to the plastic opening tool to disconnect the battery from its motherboard socket.
Lift the battery up and out of the chassis.
To reassemble your device, follow these steps in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
