Einleitung
This guide will teach you how to take apart your laptop in order to get to the processor, fan, graphics card, and many other important components. Through the steps listed below, you will be able to identify and replace your laptop's processor!
Was du brauchst
Turn your laptop over, and press on the latches to remove the battery.
Unscrew the ten screws with a Phillips Head #1 screwdriver.
Eight screws are 3mm.
Two screws are 4mm.
Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
Lift the connection between the screen and motherboard with a plastic spudger.
Remove the yellow and the clear tape.
Lift the motherboard from the frame with a plastic spudger.
Set the frame of the laptop aside, and turn the motherboard over.
Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
Disconnect the cable connecting the fan to the motherboard.
Lift the fan part from the processor.
Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
Lift the processor up away from the socket.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
