Zum Hauptinhalt wechseln
Asus X401A Processor Replacement
Was du brauchst
  1. Asus X401A Processor Replacement, Processor: Schritt 1, Bild 1 von 2 Asus X401A Processor Replacement, Processor: Schritt 1, Bild 2 von 2
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus X401A Processor Replacement: Schritt 2, Bild 1 von 3 Asus X401A Processor Replacement: Schritt 2, Bild 2 von 3 Asus X401A Processor Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
    Frag FixBot
  3. Asus X401A Processor Replacement: Schritt 3, Bild 1 von 3 Asus X401A Processor Replacement: Schritt 3, Bild 2 von 3 Asus X401A Processor Replacement: Schritt 3, Bild 3 von 3
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
    Frag FixBot
  4. Asus X401A Processor Replacement: Schritt 4, Bild 1 von 3 Asus X401A Processor Replacement: Schritt 4, Bild 2 von 3 Asus X401A Processor Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
    Frag FixBot
  5. Asus X401A Processor Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
    Frag FixBot
  6. Asus X401A Processor Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
    Frag FixBot
  7. Asus X401A Processor Replacement: Schritt 7, Bild 1 von 2 Asus X401A Processor Replacement: Schritt 7, Bild 2 von 2
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
    Frag FixBot
  8. Asus X401A Processor Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the wire connecting the speakers.
    Frag FixBot
  9. Asus X401A Processor Replacement: Schritt 9, Bild 1 von 3 Asus X401A Processor Replacement: Schritt 9, Bild 2 von 3 Asus X401A Processor Replacement: Schritt 9, Bild 3 von 3
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
    Frag FixBot
  10. Asus X401A Processor Replacement: Schritt 10, Bild 1 von 2 Asus X401A Processor Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
    Frag FixBot
  11. Asus X401A Processor Replacement: Schritt 11, Bild 1 von 2 Asus X401A Processor Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
    Frag FixBot
  12. Asus X401A Processor Replacement: Schritt 12, Bild 1 von 3 Asus X401A Processor Replacement: Schritt 12, Bild 2 von 3 Asus X401A Processor Replacement: Schritt 12, Bild 3 von 3
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ohio State, Team 1-4, Wilder Spring 2017 Mitglied von Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 2,331
