Einleitung
Is your trackpad not responding to touch? Are the buttons on your trackpad malfunctioning? Replacing your trackpad may help address these issues.
Was du brauchst
Use a Phillips Head #1 screwdriver to unscrew the eight 3mm screws.
Use a Phillips head #1 screwdriver to unscrew the two 4mm screws.
Removing the white wiring from the trackpad.
Continue removing the wire until you get to the end.
Fold up the latch on the where the cable meets the motherboard.
Use a spudger to lift the ZIF connector tabs up.
Remove the black and the white ribbon cable.
Remove the entire keyboard covering.
Lay the keyboard cover down with the keys facing down. This component contains the track pad. You will be working with this component until you reassemble.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Using a PH0 Phillips Screwdriver, remove the two screws located within the circles of the band aid seal.
Begin peeling back the band aid tape. Use the plastic spudger if necessary. This will allow you to free up the trackpad.
2 weitere Personen haben diese Anleitung absolviert.
