Was du brauchst
Use a Phillips head #1 screwdriver to remove the eight 3mm screws.
Use a Phillips head #1 screwdriver to remove the two 4mm screws.
After removing the screws from the underside, flip the laptop over and, using a plastic opening tool, remove the keyboard panel
Using a Phillips Head 1 Screwdriver, remove all screws securing the motherboard to the frame of the laptop
Use a spudger to lift up on the ZIF tab and remove the USB/charing port ribbon cable.
Use a spudger to release the speaker's bundled cable from the connector.
Peel back the tape securing the cable for the laptop's screen. It is not recommended you disconnect the cable at this time, as you risk damaging the cable.
Using the plastic spudger tool, lift up the fan from the frame of the laptop using a prying motion, which will also lift the motherboard
As you lift the motherboard, disconnect the video cable mentioned in the previous step.
Identify the wireless card on the underside of the motherboard and remove the 2 screws holding it in place
Remove the wireless card along its angle, and insert your replacement card at the same angle.
2 weitere Personen haben diese Anleitung absolviert.
