Zum Hauptinhalt wechseln
Asus X501A-RH31 Touch Pad Replacement
Was du brauchst
  1. Asus X501A-RH31 Touch Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Touch Pad Replacement: Schritt 3, Bild 1 von 2 Asus X501A-RH31 Touch Pad Replacement: Schritt 3, Bild 2 von 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Touch Pad Replacement, Keyboard: Schritt 4, Bild 1 von 2 Asus X501A-RH31 Touch Pad Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Touch Pad Replacement: Schritt 5, Bild 1 von 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Touch Pad Replacement: Schritt 6, Bild 1 von 2 Asus X501A-RH31 Touch Pad Replacement: Schritt 6, Bild 2 von 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Touch Pad Replacement: Schritt 7, Bild 1 von 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Touch Pad Replacement: Schritt 8, Bild 1 von 1
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Touch Pad Replacement, Touch Pad: Schritt 9, Bild 1 von 2 Asus X501A-RH31 Touch Pad Replacement, Touch Pad: Schritt 9, Bild 2 von 2
    • Flip the keyboard over so the side without the keys is facing you.
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • The three screws are 2mm in length, 6.5mm in diameter.
  10. Asus X501A-RH31 Touch Pad Replacement: Schritt 10, Bild 1 von 2 Asus X501A-RH31 Touch Pad Replacement: Schritt 10, Bild 2 von 2
    • Detach the white data cable on the back of the touch pad.
    • Use tweezers to pull the white plastic piece up that is holding in the cable.
  11. Asus X501A-RH31 Touch Pad Replacement: Schritt 11, Bild 1 von 1
    • Peel the tan tape that holds the touch pad to the back of the keyboard.
    • Slide the touch pad up and out of the metal plate located near the bottom on the touch pad and keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Christopher
359 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G3, Bailey Fall 2017
UMASSD-BAILEY-F17S3G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 516
