Einleitung
The screen or display of your laptop may break because of physical damage. If so, you can replace it using this guide.
Was du brauchst
Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
Using your hands, grasp the screen frame at it's base near the laptop hinge.
While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
Flip the laptop around and lay the screen flat on your work space with the laptop hinge away from you and the keyboard assembly standing vertical.
Using the Philips #00 screwdriver, remove the 4 screws holding the laptop screen in place.
Lift the screen away from the laptop starting with the edge furthest from the laptop hinge.
