Einleitung
This guide will show you how to remove the keyboard panel for the Asus X450S.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the two 15mm Philips #1 screws.
Remove the two 12mm Philips #1 screws.
Remove the six 9mm Philips #1 screws.
Lift the side of the top.
Remove the keyboard cable.
Remove the trackpad cable.
8 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
