Zum Hauptinhalt wechseln
Asus X550ZA-SA100603E Hard Drive Replacement
Was du brauchst
  1. Asus X550ZA-SA100603E Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Remove all of the 10 bottom case screws.
    • Seven of them are 14 mm screws.
    • Three of them are 4 mm screws.
  2. Asus X550ZA-SA100603E Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • After the screws are removed, gently turn the computer to its upright position and open up the computer flap.
    • It is important to do this gently, as these pieces are loose.
  3. Asus X550ZA-SA100603E Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Pry open a gap between the keyboard and the lower piece using a spudger.
    • This will uncover all of the internals in the laptop itself.
  4. Asus X550ZA-SA100603E Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Slide the hard drive out of its position to allow room for the new one.
    • Make certain the area is clean and no debris got into the slot.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Paul Flynn
16 Reputation
2 Anleitungen geschrieben
IUPUI, Team S5-G5, Wilson Spring 2019 Mitglied von IUPUI, Team S5-G5, Wilson Spring 2019
IUPUI-WILSON-S19S5G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 419
