Einleitung
How to disassemble the laptop and replace the Processor.
_______________ Video manual: _______________
Was du brauchst
Einführungsvideo
The Keyboard is held by 5x locking clips.
Pick up a little the one side of the Keyboard and start opening the clips one by one.
Disconnect the Keyboard flex cable from the mother board and remove the KB.
Remove 3x Philips screws.
Disconnect the two small flex cables:
Power On button flex cable
Touch pad flex cable
Unscrew the two Philips screws and remove the HDD / RAM Cover.
Remove three screws securing the hard drive caddy (hard drive assembly).
Slide the hard drive assembly to the left to disconnect it from the motherboard.
Disconnect the two coaxial antenna cables from the Wi-Fi card.
Remove any Memory or Dummy card.
The bottom cover is held by 10x Phillips screws. Remove them.
With a plastic tool separate the Upper cover and remove it.
Disconnect:
The Microphone cable
The LCD Display flex cable
Remove 3x Pillips screws.
Lift the board first from the right edge.
There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100
Disconnect the Fan cable from the Motherboard.
Remove the screws (4x Phillips screws) that hold the cooling system to the Motherboard
Remove the Cooling System.
Counter clockwise release the screw securing the CPU using a flat head screwdriver.
Intel Core i3-2370M
4 weitere Personen haben diese Anleitung absolviert.
5 Kommentare zur Anleitung
Hi, someone let me know if I can upgrade a Asus X55VD's processor from B980 to i7 2670QM.
Or what to take into account? Power usage? Should I only get an i5?
Thanks in advance
Hi there what about the shutdown every 30min exactly
