Zum Hauptinhalt wechseln
Asus X751L Battery Replacement
Was du brauchst
  1. Asus X751L Battery Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: Schritt 3, Bild 1 von 3 Asus X751L Battery Replacement: Schritt 3, Bild 2 von 3 Asus X751L Battery Replacement: Schritt 3, Bild 3 von 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: Schritt 5, Bild 1 von 2 Asus X751L Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: Schritt 6, Bild 1 von 3 Asus X751L Battery Replacement: Schritt 6, Bild 2 von 3 Asus X751L Battery Replacement: Schritt 6, Bild 3 von 3
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
John Enderton
576 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 17-2, Blackwell Spring 2017 Mitglied von USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
Very nice, thank you !
anh
barzamjavel - Antwort
very nice, thank you !
Anh
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - Antwort
Your instructions were easy to follow. Thank you!!!
theresa collet - Antwort
very helpful
khan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 54
Insgesamt: 12,785
