Einleitung
This guide will walk you through the process of replacing a broken or faulty keyboard on the Asus X751L.
Was du brauchst
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Flip the laptop over and open the lid.
Pry around the edges of the laptop base using the plastic opening tool.
Carefully lift the keyboard up.
Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
