Einleitung
This guide will assist you in replacing a faulty wireless card in your ASUS X751L.
Was du brauchst
With the screen closed, place your laptop upside-down with the front facing you.
Remove the six 14.6mm Phillips #00 screws.
Remove the four 6.6mm Phillips #00 screws.
Flip the laptop over and open the lid.
Pry around the edges of the laptop base using the plastic opening tool.
Carefully lift the keyboard up.
Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
3 weitere Personen haben diese Anleitung absolviert.
