Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show how to replace the battery on an Asus Z54C-JS31 laptop. Over time batteries naturally lose their ability to hold a charge and will need to be replaced.
  1. Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery. Slide the switch on the top right corner to the right. Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 129
