Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
When a keyboard no longer functions correctly it is necessary to replace it to regain proper function.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery. Slide the switch on the top right corner to the right. Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  3. Turn the laptop to its normal position and open the display to show the keyboard. Gently push back the five tabs holding the keyboard down using the plastic opening tool.
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  4. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
Abschluss
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 104
