Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The optical disc drive allows the laptop to read and play CDs and DVDs. If it is not functioning properly, this guide will explain how to replace it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery. Slide the switch on the top right corner to the right. Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Turn the laptop to its normal position and open the display to show the keyboard. Gently push back the five tabs holding the keyboard down using the plastic opening tool.
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  3. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out. Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  4. Remove the 3mm screw with a Phillips #000 screwdriver. Slide out the optical disc drive by pulling it away from the laptop. Slide out the optical disc drive by pulling it away from the laptop.
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
Abschluss
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 45
