Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The WiFi card allows the laptop to connect to the Internet wirelessly. If you're experiencing network connection issues you may need to replace your WiFi card.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery. Slide the switch on the top right corner to the right. Slide and hold the switch on the top left corner to the left and carefully remove the battery.
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel. Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Slide the back panel off by placing a hand on each corner and pulling the panel towards you. Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  5. Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece. Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece. Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  6. Remove the 3mm screw from the top right corner of the WiFi card  using a Phillips #0 screwdriver. The WiFi card will pop up. Grasp it and pull it out of its slot. The WiFi card will pop up. Grasp it and pull it out of its slot.
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
Abschluss
Mark DeSimone
801 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Mitglied von UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 27
Insgesamt: 559
