Einleitung
- If you need to replace the rubber feet on the bottom of the laptop, you do not need to unscrew anything. The only tool needed is a metal spudger.
Was du brauchst
Turn laptop over.
Use the metal spudger to pry rubber feet off in the four corners of laptop.
Abschluss
